1937 ul cam cover
  • ldfly112
    • Sep 2017
    • 146
    1937 ul cam cover
    working on a 1937 ul. needing a cam cover anyone have any experience with a aftermarket cam cover
  • 41craig
    • Nov 2010
    • 411
    Not the UL, but I bought the ribbed Knucklehead cam cover from V-Twin and sent it back. Was not even close to original look. Just make sure that you check out their return policy before buying.
    Craig
    • ldfly112
      • Sep 2017
      • 146
      Thanks Craig
      • EricOlson
        • Jan 2011
        • 581
        Welcome to the forum ldfly112, I saw your other post and it sounds like you've had some nice rides. I'm currently working on getting my 40 UA back on the road. I don't know anyone with an original cam cover for sale, but you should be able to get a repop at AAOK. https://aaok.com/index.php/motor-fla...ver-parts.html. I've bought some parts from them for my bike and so far they seem pretty good. You could also try posting your request in the "wanted" section of this forum.
        Love to see some pictures of your bikes!
        Eric Olson
        Membership #18488
          • 4791
          There is an original on eBay right now.
          https://www.ebay.com/itm/23406504481...YAAOSwaNpg1faw
          • ldfly112
            • Sep 2017
            • 146
            Thanks Rubone I have found another its a 1940 with fins but i believe it will work
            • kitabel
              • Sep 2018
              • 471
              It will (although the alignment with the shafts may not be perfect).
              Check the flutter valve for free movement and replace if needed.
              The Linkert Book
              • ldfly112
                • Sep 2017
                • 146
                After looking at the cam cover on e bay i purchased it . Thanks again Rubone
