VL Banjo bush
  • zig1
    • Jul 2007
    • 51
    VL Banjo bush
    Does somebody have the dimensions of a VL banjo speedo drive bush ? I plan to make one and would be easier if I had the measurements . Thanks
  • HDSmitty
    • Jul 2017
    • 282
    Not sure what you are referring to as the VL did not have a factory speedometer. They could be fitted with a Corbin speedometer for which drive units are readily available. There is a large spacer on the axle when there is no speedo and a smaller spacer when speedo (and corresponding drive unit) are utilized. Hope this helps......Smitty
    • zig1
      • Jul 2007
      • 51
      Smitty ,Thanks for your reply . I have come up with a part # under Corbin speedometer parts , 11184-32B axle sleeve -1932-35 74" twins & 1935 45 twins . Doc Schuster book says " to fit a Harley the center bushing hole was 11/16 and the bushing had a sturdy flange that extended 1/4" past the outer surface of the drive unit frame ". I would like the diameter and overall length measurements please .
