1930 VL rear fender bracket length
  • Chuck#1848
    Can somebody here tell me the length of the rear fender bracket mount length is?
    Is it 12 1/2 or is it 11 1/2 this is the part that bolts the rear hinged portion of the rear fender together.
    Thanks in advance
  • JohnC
    My 1931 is 12 1/2". Same fender is used.
    • Chuck#1848
      thanks John,
      I have one that is 12 1/2" long it is not attached to the fender and need another.
      I spotted a set on Ebay that is listed as being used for a jd I just wanted to be sure of what I had was infact correct before I decided to bid on the 11 1/2" long pair.
      • JohnC
        Hello Chuck,
        The ones on ebay that are 11 1/2" are the same as the ones on my 1923 JD. Good luck! JohnC
        • Chuck#1848
          Thanks John.......and the search goes on
          I see a couple of JD's listed on ebay today a 25 and 27
