1934 to1936 VL Oil Pump Cam Shaft Sprig
  • John Guntner
    • Feb 2007
    • 192
    Cam Shaft Srig? I mean Spring. Oops. This is for you out there working on the oil pump. In the picture, the spring on the left is an aftermarket cam shaft spring part number 711-32. The spring the right in the picture shows an original spring. Notice anything? The original cam shaft spring rotates to the right. The aftermarket spring rotates to the left. I was fortunate enough to have salvaged the old spring so if anyone wants a spring, it's available. Hahaha
    This gallery has 1 photos.
