wiring clips
  • dzec
    wiring clips
    I am restoring a '37 model U and do not know where the following harnes clips should be located. Any help would be appreciated, 4727-30 and 4730-30A.
  • Johnny
    Try Harbor Vintage at (802) 434-4040
    • Tommo
      4730-30A goes around the headstock and 4727-30 holds the tail light wiring to the left hand leg of the frame between the seat post and the cross casting that the mudguard mounts to.
      This is where I have always fitted them and if I am wrong I will learn also.
      Never too old to learn.
      Regards, Tommo
      • dzec
        Thanks for the info. I called Dave at Vintage and he gave me the same locations as Tommo. I also apperciate the quick answers. This forum is invaluable.
        • Tommo
          When you put them on wrap the frame tube with some masking tape to protect the paint and slide the clip over this. It is then easy to slide the clip sideways into position and remove the tape.
          Hopefully no scratches but be careful because the edges of the clip are sharp.
          Tommo
