Motorcycle gurus, please share your wisdom!
This is a 1935 VLD which is stock. The engine starts easily. Both cylinders fire. Good engine power while riding. After warmed up the engine will pop slightly at idle. During riding the engine will pop and cut at speed. Sometimes after warming up if left to idle the engine will stall out after a minute or so. Here are the specs.
Ignition system:
- fresh set of NGK A-6 spark plugs (heat range #3) with a .030 gap
- points set to .022 gap
- flywheel timing mark set to middle of rear half of timing hole
- points open right at ramp of small timing lobe as verified by the ammeter swing
- intake valve tappets adjusted to .005 (middle of Riders handbook spec of between .004 and .006 inches)
- exhaust valve tappets adjusted to .007 (middle of Riders handbook spec of between .006 and .008 inches)
Fuel system:
- Linkert M31
- 87 octane fresh gasoline
- clean tanks
- new fuel line, clean and clear
- fuel filter clean and clear
- float height set to ΒΌ from bowl top
- needle and seat show no wear and move properly
- low speed circuit clear
- high speed circuit clear
- main jet clear and fully seated in carb body
- no fuel weeps or drips anywhere in the fuel system
- Initial low speed setting is 2 full turns out (I have leaned it down once up to temp)
- Initial high speed setting it 1.5 turns out
Ignition system:
Fuel system:
- Linkert M31
- clean tanks
