Thanks to everybody for the support with the wiring diagram.
This is just a great community!
I spend the whole day checking the wiring on that bike and I could not find any failure. Thats the good news.
The bad new is that I do not have charge amps.
Here is what I checked and maybe somebody can give me feedback if this is correct.
I disconnected the generator from the regulator and started the engine with battery only.
I measured the voltage between the generator poles and there was none (0)
(I also did the polarisation procedure on the gen before)
I draw the conclusion that the generator must be defect -right?
Is there anything else I should check ?
I again appreciated any feedback on this problem.
regards
Oliver
regards
Oliver
