Mystery VL kicker sector gear
  • MMasa
    • 1192
    I have what appears at first glance to be a VL transmission kicker sector gear (the -31 or -32 one and not the -16 JD style)
    Anyway, it is different in one major way, it has a larger OD and more teeth.
    Being a sector gear, it only has gear teeth for a section of the OD, however, if it were a complete circle with teeth all around the periphery, it would have a slightly larger OD and at least one or maybe two additional teeth than the standard kicker gear would.
    As a result it doesn’t mesh with the mainshaft kicker gear. It would mesh with a smaller mainshaft kicker gear if one existed.
    What do I have here?
    Thx in advance.
    Mark Masa
    Mark Masa
    www.linkcycles.com
    Dear Mark, I'd like to know as well. They are being sold on eBay and I'm being contacted because these 13 tooth versions don't fit the VL.
    • MMasa
      • 1192
      I got this one in a pile I bought a while back. Sold it on eBay without noticing the difference and the buyer pointed it out after he received it. I accepted the return obviously.
      Steve, if you don’t know them I’m going to say that no one does.
      Mark
      Mark Masa
      www.linkcycles.com
