1937 W Oil Filter
  • Rex
    1937 W Oil Filter
    Would a big twin canister type oil filter be usable on my 1937 W engine? I'm willing to fabricate my own oil lines.
    If it would work, should it be in the oil pump supply line, or the oil tank return line?
  • DOC HARLEY
    PUT IT ON THE RETURN LINE ONLY. DOC HARLEY
    • Rex
      Oil Pressure Indication Delay
      Thanks for the oil filter advice, Doc Harley! I'll put that installation on the list of future modifications.
      Here's another one concerning the same 1937 W engine.
      Today I started it for the first time since a proffessionally done complete top to bottom rebuild. It ran twice for only about 5 to 10 seconds each before a carb float adjustment problem became apparent. The oil pressure light didn't go out on either run.
      How can I determine that oil is actually flowing into the engine?
      How long should I wait for the oil light to go out?
      The manual says that I should be able to see an oil return stream in the tank. Where would that be in relation to the filler hole?
      The temperature in my shop is @ 60F, oil is new 50 weight, all tank lines are clear, and tank was cleaned and treated with POR15 Marine Clean and Metal Ready, but not the sealer.
      I don't want to burn up this motor.
      • DOC HARLEY
        Re: Oil Pressure Indication Delay
