1949 WL Rear Stand Clip
  • 1962300
    • Jun 2015
    • 58
    I have the rear stand, with its rear fender clip to hold UP the rear stand when riding.
    The stand rattles a decent amount, though it seemed not to when I installed it years ago.
    Anyone know if I need to bend the clip up or down to tighten up its ability to hold the stand in the upright position?
    Or do I split a piece of fuel line & wrap it on the rear stand bar that is held by that clip; ha!
    Thanks!
    Matt Allyn
    1932 Ford Roadster / 1949 Mercury Coupe / 1949 Harley Davidson 45 / 1957 Cadillac Eldorado Biarritz Convertible / 1957 Lincoln Premiere Convertible / 1959 Lambretta TV175 / 1962 Sunbeam Alpine Convertible / 1962 Chrysler New Yorker Station Wagon / 1962 Chrysler 300H / 1962 Chrysler 300 Sport / 1964 International Travelall / 2015 Tesla Model S
  • Sargehere
    Member since 1972
    • Jul 2006
    • 971
    I've had a one-inch piece of split rubber hose in my 37UL's rearstand catch for over thirty years. It's almost invisible, quiet, and no maintenance.
    Gerry Lyons #607
    http://www.37ul.com/
    • ammorest
      • Sep 2008
      • 298
      Matt, don't even try to bend the catch; they are made from spring steel and they don't want to bend. Another method to tighten the catch is to remove the lower screw and nut and install 1/4 inch flat washers between the catch and the fender. Just use enough washers to make the stand fit snug in the catch. It may require a longer screw.
      Dave
