WL front brake panel
  • hdhikaru
    • Feb 2010
    • 217
    Hi experts,
    please advice what this slide for.
    tks
    Shin
  • Architect
    • Dec 2014
    • 283
    You should have one rocker stud on that side with a nob on the end of it. When installing the front wheel, the nob goes between those two forks to keep the brake from rotating. I hope that makes sense. And I hope that was what you were asking.
    • hdhikaru
      • Feb 2010
      • 217
      Hi Architect,
      thanks!! may I see a pic of the rocker stud properly installed?
      tks
      Shin
      • RichO
        • Dec 2001
        • 903
        To me it looks like the anti-rattle device they started in 1929?
        DrSprocket
          • 2025
          That plate gets locked down against the rocker when the axle is tightened. In order for the backing plate to pivot when the rockers actuate due to spring compression it allows the backing plate to 'float" otherwise the whole assembly would be bound up.
          • hdhikaru
            • Feb 2010
            • 217
            thank you guys..
            I just found that its called slot in brake stabilizer plate. should be fitted over extended end of rocker plate stud....
            will try.
