Mystery nut - mystery to me anyway
  • NCriding
    • Jul 2014
    • 71
    This nut with a winged flange came with my 1936 VLD bit-sa project, the head is 11/16"
    Can anyone tell me what it does, and what the part number is?
    1936 VLD in process
    1969 Honda Z50 K1 perfect!
    1985 Yamaha RZ350 resto-mod
    2006 KTM 950 Adventure
    2019 KTM 300 XCW
  • larry
    • May 2009
    • 247
    Front motor mount, under the generator, Big Twin.
    • len dowe
      • Oct 2002
      • 520
      A special lock washer goes with the bolt.
      AMCA #765
        • 4789
        The nut drops into the case from above, the tab keeps it from turning. As stated, the bolt has a special retaining washer so once it is tight the washer is bent up to lock it in place.
        • NCriding
          • Jul 2014
          • 71
          Gentlemen, thank you for the responses!
          Is this nut supposed to fit into a recessed bolt hole in the case? If so, the case was never drilled/machined for it.
          Per the picture, I did insert and tighten the nut, without that retaining washer (I don't have one). If it had a washer [U]under[U]it, the top of the nut would be high enough to contact the generator.
          Here you can see that wear ring, why not just use the same bolt, washer, castle nut with cotter pin as the other 3 holes? The cotter pin might be a trick to get in, but with forceps I'm sure I could manage.
          1936 VLD in process
          2019 KTM 300 XCW
            • 4789
            The nut was a new for '36 part and not likely used on a VL, just the new 36 OHV.
            • Sargehere
              Member since 1972
              • Jul 2006
              • 971
              And the UL beginning in 1937, with no washer. The hole was designed to keep the triangular flange on the nut
              from turning at all.
              Gerry Lyons #607
              http://www.37ul.com/
              • NCriding
                • Jul 2014
                • 71
                Thanks Sarge, now it goes in the spare parts bin
                1936 VLD in process
                2019 KTM 300 XCW
