42 WLA running issues
  • emyoung35
    • Jun 2019
    • 21
    I recently entered the antique motorcycle world and purchased a 1942 HD WLA that had been "rebuilt". It has a Mukini carb, that I since replaced new from Harley 45 restorations that has remedy the leaky carb. My main issue is the Circuit breaker points keep moving. Initially someone had modified the circuit breaker to accept a universal car point set up. I have replaced that too form Harley 45 restoration new points, condenser, and circuit breaker bottom. I set the proper gap, it runs and the points keep moving after a short time and the bike quits. I have tightened the bolts as tight as I could get them, even broke one. Yesterday I finally added loctite blue to see if that helps. Any other recommendations as it is driving me crazy. I also had an intake leak, I replaced the bolts and put in Peek seals but haven't had the chance to "bubble test" it. I have read many of the articles on here and know there is a wealth of knowledge. All help greatly appreciated form an AMCA newby. Thanks in advance Erik
  • tomfiii
    • Jun 2007
    • 314
    I would look at shaft movement and the rubbing block for wear.
    • Architect
      • Dec 2014
      • 283
      Bubble test is mandatory before any kind of tuning, if the manifold is leaking all sorts of bad and strange things will happen preventing you from tuning the bike. Hopefully others will jump in about your points. Good luck.
      • emyoung35
        • Jun 2019
        • 21
        Thanks for the advice, plan on bubble testing in a couple of days.
        • emyoung35
          • Jun 2019
          • 21
          Thanks Tomfiii for the advice, what would be the steps you take to do that? Thanks for your help. Erik
          • emyoung35
            • Jun 2019
            • 21
            More specific details
            Purchased 42 HD WLA with Mikuni carb with overhauled engine “running great”
            Would start but wouldn’t stay running. What I have done:
            New plugs .025 gap (previous plugs showed wayyyyy too rich)
            Carb had a serious leak and internally tired. Replaced new from HD 45 restoration
            Circuit breaker was running modified car points on lobe, replaced with new again HD 45 Resto
            I gap the points full advance timing is right .022
            Seems the gap moves after a couple of minutes new CB bottom, screws, washers, and condenser
            New Peek seals and manifold nuts had noticible leak, bubble test tomorrow
            New battery, coil seems solid
            All help greatly appreciated, have ridden it a total of 5 minutes and pushed it wayyyy more
            • emyoung35
              • Jun 2019
              • 21
              Bubble test shows no manifold leaks. I did realize the non-45 after market coil had cracked. Hopefully replacing that will finally remedy the issue.
              • emyoung35
                • Jun 2019
                • 21
                After everything, points will move every third time I ride it. Going to try Beyond2000 to hopefully remedy the issue. Has anyone tried this product? Thanks,
                Erik
                  Dear Erik, I've tried electronic ignition on my bobber/racer but saw no improvement and went back to good old points.
                  • Architect
                    • Dec 2014
                    • 283
                    Erik
                    Good product, would recommend. BUT you must have a coil with the correct OHM's or it will eat the coil, constantly. Call the guy and get the scoop so you only have to do it once. I current run a 3 OHM coil for a Shovel, bike runs great even if it doesn't look 100% perfect.
                    • emyoung35
                      • Jun 2019
                      • 21
                      Put on the Beyond 2000 and runs beautifully. Thanks for all the advice.
                      Erik
