WL oil gauge
  • hdhikaru
    • Feb 2010
    • 217
    WL oil gauge
    hi there,
    one basic question.
    oil level should be between danger and refill line.... right?
    tks
    Shin
    • 4789
    No, it should be above refill line. Refill line means it is a quart low.
    • hdhikaru
      • Feb 2010
      • 217
      thanks! .. so. upto where should be enough? I think the tank should not be filled up .. as the vent pipe should not be covered .....
      • aumick10
        • Nov 2018
        • 465
        if your gearbox is dry, look in the manual for the correct amount of oil. Fill the box with that amount. Put in the dipstick and make a mark where the oil level is. Now you have a permanent high level mark.
          • 4789
          Not a gearbox, a 45 oil tank.
          • aumick10
            • Nov 2018
            • 465
            Sorry, same process
            • kitabel
              • Sep 2018
              • 471
              The tank should never be full, there must be an air space to allow for expansion due to operating temperature.
              The engine will run as long as there is any oil going to the feed pump, this is not like a car engine where the pump pick-up must be covered. If the oil level is low the oil temperature will rise but the pressure in the engine will continue.
              The Linkert Book
              • jug
                • Jul 2018
                • 112
                If you are running a servicar install a square shovelhead oil tank under the seat with a dip stick and filter all in one and gain the extra space for gas. Just My 2 cents worth.
                  • 4789
                  Factory specification..
                  • hdhikaru
                    • Feb 2010
                    • 217
                    got it!! thanks!
                    • kitabel
                      • Sep 2018
                      • 471
                      These engines have very few pressurized plain bearings (only in the cam cover), and run quite a while with very little oil (although obviously it's a bad idea).
                      The Linkert Book
