46WL transmisstion oil
  • hdhikaru
    • Feb 2010
    • 217
    Hi,
    please advice how do you check if the oil is certain amount in the case?
    tks
    Shin
  • Architect
    • Dec 2014
    • 283
    Bike must be vertical, you should see the oil when you remove the fill plug. If you fill it on the jiffy stand, she will leak. I like to fill it pretty much to the opening, just before it starts to spill out. They leak, so for me a little extra doesn't hurt. Check often.
      • 2042
      That is way too full
        • 8243
        I didn't like to fill them that far either, Folks!
        It was such a pain to throw them on their side to drain it.
        • len dowe
          • Oct 2002
          • 520
          Turkey baster.
          AMCA #765
          • hdhikaru
            • Feb 2010
            • 217
            so.... should use small stick or something to check the oil level at vertical position?
            • RCamp
              • Jul 2012
              • 99
              With the bike level, use a flashlight and if you can just see oil at the bottom of the filler spout, you have enough oil in it.
              Any more and it will tend to push it out through the various seals.
              • DaveAus
                • May 2010
                • 41
                I like to fill them just to the point where I can see the oil through the plug hole when the bike is vertical
                  • 2042
                  I have always done it as RCamp said.I have been riding 45s for over 35 years.
                  • hdhikaru
                    • Feb 2010
                    • 217
                    thank you guys!
