Harley RL Early WL Horn Mount Question
  • MMasa
    • 1192
    I have these two types of horn mounts for an RL / early WL.
    Notice that the one stye has an extra tab and hole for mounting something.
    Can anyone tell me what the purpose, years etc the one with the extra tab is for.
    Thanks in advance.
    Mark Masa
    Mark Masa
    www.linkcycles.com
    Dear Mark, these are for the 1936-39 Harley small twin with the I-beam forks as you probably know. The one with the hole I have seen before and is possibly Servicar. I had this discussion with Wheels Through Time a few years back and they may have a more definite conclusion.
    • MMasa
      • 1192
      Steve
      Yes, they are the longer 45 version as opposed to the shorter length used on the V series.
      Thanks for the lead on the info. Did you talk to Matt, Dale, or someone else at the museum?
      Mark
      Mark Masa
      www.linkcycles.com
        Dear Mark, it was Dale I spoke to, but he's not taking calls anymore so you'd better try Matt.
          • 2042
          Palmers book page 846 prototype 1939 servicar has a screw in that position.Maybe because ride control could now fit with towbar in '39 & it holds wires ????Interesting that the '38 W pics show a hole in the side but nothing attached.'37 does not have the side hole??That would indicate the other brackets were actually '36-'37
            • 5955
            It appears to be an electrical terminal.
            • MMasa
              • 1192
              Duffy and Chris
              Thanks for the info. I wasn't sure which style I needed to use on my 36 RLD.
              MARK
              Mark Masa
              www.linkcycles.com
                • 2042
                I had to pay a small fortune for mine 30 years ago
                  • 5955
                  This is discussed at the bottom of page 605 and top of 606 in Palmer's second edition.
                  • MMasa
                    • 1192
                    Thanks Chris
                    I'll look it up in the morning.
                    Mark
                    Mark Masa
                    www.linkcycles.com
