M51 v M55
  • Tommo
    • Sep 2001
    • 1320
    M51 v M55
    A bit of quick research in Bruce Palmers book shows that internally both carbs are identical.
    There are two external differences one minor but one is a major difference.
    The minor one is the throttle lever 1238-36 / 37 / 40 depending on application.
    The major one is the carb mounting flange with one being 3 bolt and the other being 4 bolt.
    I'll hold my hand up and say knuckles are way out of my league and what follows could prove to be wrong but here goes.
    The M5 fitted to 1936-39 knuckles I suspect was a 3 bolt mount and as most part numbers for the inlet manifold change to -40 part number in my late model parts book I'm led to suspect that that is when the 4 bolt manifold started.
    Robbie or some knuckle guru help me here.
    The main point here with regard to Steve's bike is that I'm at a bit of a loss to understand how a 4 bolt mount carb is fitted to a 3 bolt manifold. Who knows, anything's possible
    Does that answer your question kitabel
    Peter Thomson, a.k.a. Tommo
    A.M.C.A. # 2777
    • 4784
    Tommo, an M55 is a three bolt carb.
      • 5950
      The M55 was the factory replacement for the M5.
      • kitabel
        • Sep 2018
        • 471
        Is that what he actually said? Or the conclusion that you draw from his commentary?
        No, they're not.
        The Linkert Book
          • 8233
          From those that crossed my benches, Folks,...
          Other than a different main nozzle,
          The two differences that come to mind are that the M55s did not have the 7-64 bowl, nor were the bodies nickel, as were pre-War M51s.
          Post-War differences escape me without an M55 currently on the bench.
          Some of you may have noted that the Pre-War M51s were milled and drilled to accept the OHV bowl.
          Just wanted to get those out of the way, thanks.
          • shinedogg
            • Sep 2009
            • 151
            My M55 has the early bowl with the cast #, no drain plug and is 3 bolt.
            Steve
