1949 WL Seat Pogo Adjustment
  • 1962300
    • Jun 2015
    • 58
    What are the proper steps to stiffen the pogo seat?
    My 172 pounds seems to require more spring stiffness.
    I think there's an adjustment bolt at the base of the pogo stick tube??
    Thanks!
    Matt Allyn
    1932 Ford Roadster / 1949 Mercury Coupe / 1949 Harley Davidson 45 / 1957 Cadillac Eldorado Biarritz Convertible / 1957 Lincoln Premiere Convertible / 1959 Lambretta TV175 / 1962 Sunbeam Alpine Convertible / 1962 Chrysler New Yorker Station Wagon / 1962 Chrysler 300H / 1962 Chrysler 300 Sport / 1964 International Travelall / 2015 Tesla Model S
    • 8243
    Maybe not 'proper', 1962300,..
    But the traditional, quick, easy, and cheap assist is to toss an OHV outer valve spring over the post.
    Otherwise you toss money at it.
    PS: In light of Mr. Weiland's post, I must add: "If all other things are in order,..."
      • 2024
      You really should pull the seat post out of the bike and have a look see. Sometimes springs are broken, sometimes they squashed out and sometimes they are rusted. They also just might be too light of a setup for you. I just finished rebuilding a BT seat post this morning using some OEM and some Dave Croft (who is no longer in business) springs. Dave sold his business to Colony. Jerry
      Thanks!
      • len dowe
        • Oct 2002
        • 520
        Step by step instructions in the manual.
        AMCA #765
        • jwl
          • Dec 2001
          • 338
          Waste as much time as you like adjusting, tinkering, adding springs, etc. When you get frustrated with all of that, take Jerry Weiland's advice and solve your problem. You'll be glad you did. The spring setup from Colony is the way to go.
          • Architect
            • Dec 2014
            • 283
            At 225#, I did the spring swap, as provided by Colony. Straight forward and easy though messy. Seat no longer bottoms out and I am much more comfortable. Good luck.
