k piston
  • jug
    • Jul 2018
    • 112
    k piston
    any body out there have the dimensions of the k model pistons? the distance from pin hole to top is the main thing as I am thinking of using them when I rebuild my servi this winter.
    • 4789
    They are taller from pin to crown and won't fit your Servi without head modifications.
    • kitabel
      • Sep 2018
      • 471
      Depending on the manufacturer, up to +1/8" on the compression distance, with a shorter skirt. The weight is different, but IDK how much.
      Part of this excess height is useful in reducing the quench clearance, which is too loose in stock 45 engines. It's probably 1/16" down from the deck @ TDC now, you want closer to .015"-.025" below the deck to achieve .035" minimum clearance.
      The remainder can be made up with a fabricated stroker plate, or Bridgeport a shallow cylindrical relief in the head's gasket surface deep enough for .035" clearance and slightly larger diameter than the dome OD, like 2-7/8". The relief is the better method but will be more expensive.
      All methods increase the static compression ratio.
      The Linkert Book
      • jug
        • Jul 2018
        • 112
        Do I have to machine heads if I use no 6 heads
          • 4789
          Yes, the area in question is the same on all heads, the flat portion above the piston. If you are not trying for the extra squish why not just use 45 pistons? And without other breathing mods there would be minor gain.
          • kitabel
            • Sep 2018
            • 471
            A bit of trivia for your amusement: the only head that is both "immune" to machine work and has your 45 bolt pattern is the 1948-52 WR, which has a K-style pop-up relief, but:
            1. $$$$$$$$$$$
            2. you can't get the head on, your exhaust valve will crash the head - it's in a different place than yours
            The Linkert Book
              • 2042
              The #6 would need more clearance made than the others.It is already shorter/lower/tighter.I agree with Robbie,use 45" pistons not high top.
                • 4789
                Illustrations tend to help clear things up. Left to right, NOS #5 head, #6 head, WR head
                From the other side, not the piston interference area is the same on 5 or 6, just a slightly smaller combustion area. The casting is the same just machined thinner for a 6. WR head illustrated the pocket needed for pop-up K pistons.
                The difference in height is obvious, 45 left, K right. Skirt is actually the same length but is radiused for flywheel clearance.
                • jug
                  • Jul 2018
                  • 112
                  thanks for all the info you guys sent my way. I am sure I will have more questions later. any other things you guys think of about the heads and anything that helps me get a little more out of the old 45 send it . thanks to all
                  • jug
                    • Jul 2018
                    • 112
                    Rubone, great pictures. helps a great deal. keep the good stuff coming.
                    • kitabel
                      • Sep 2018
                      • 471
                      All non-pop-up 45 heads (1929-73 D, R, W, G; iron or aluminum; regardless of compression ratio) have the quench ledge in exactly the same place: milled flat with the head gasket surface.
                      Milling the head increases the CR but does not change the P-H clearance.
                      Milling the cylinder (head gasket surface or flange) does both.
                      Harley-Davidson intended all sidevalve engines including UL, VL, K, etc. to have quench (1923 Ricardo patent), which was the advantage that made the previous IOE (JD etc.) engines obsolete and permits reasonable compression ratios. There is nothing dangerous, radical, or experimental about it.
                      The sloppy factory tolerance made this distance too large to be fully effective. Getting it down to .035" increases:
                      1. torque
                      2. chamber turbulence, squish, and mixture homogenization
                      3. engine vacuum
                      4. gas mileage
                      Reason not to do this: money.
                      The Linkert Book
                        • 2042
                        WLD cylinders have a machined flow to the piston from the valves that helps.Tom Sifton style.
                          • 4789
                          Actually WLD do not unless it is tuner added. WLDR does though, although they are extremely thin on the ground as '41 was the last of them.
                          NOS WLD cylinders
