45 head work
  • jug
    • Jul 2018
    • 112
    45 head work
    I was told the no.6 45 heads are higher compression. so what can I mill off of a no5 head? or are there more changes to be done or is it worth the trouble? will make my 69 servi a little faster along with the 30 tooth motor sprocket?
    • 2024
    Before you ruin a nice set of heads why don't you buy a really cheap set from me to play with. I have a whole box of heads that have mainly fin issues that I would sell for $20 apiece + shipping Jerry
    • jug
      • Jul 2018
      • 112
      Jerry, what other 45 parts do you have?
      • kitabel
        • Sep 2018
        • 471
        Consider shortening the cylinders by about .050" (from the top is easier but removes part of your current valve job, doesn't affect manifold or exhaust position; from the flange is more difficult, leaves valve job alone, moves manifold down and closer to nipples). This gives you much better piston to head quench @ TDC, .035" min.
        No, milling the head doesn't do this.
        The Linkert Book
        • jug
          • Jul 2018
          • 112
          ok guys, we got tops milled off to get to .035 quench as talked about before. now I cant find any posts that tell how much to take off of the no. 5 heads that will help also. I am using k valve springs larger intakes, cleaned out the ports, will be running a mikuni 34mm carb, copper head gaskets. anything else you guys can offer that is not to costly let me know. thanks for all the help.
          • kitabel
            • Sep 2018
            • 471
            IIRC it takes about .100" mill to get the chamber down to #6 size, the new gasket surface will be only slightly taller than the bottom of the last fin in the casting.
            When you mill the heads, you begin to reduce the clearance between the intake valve head and its relief pocket. The offending area is typically the corner radius, which can be Dremeled out to give at least 1/16" minimum clearance to the valve when fully open. This will be worse with more lift (duh), or a larger intake valve such as the KNS Cycle. Ideally, the roof of the intake valve pocket should be deepened to the lift + .090" at right angles to the valve stem (not horizontal) of 4.5 degrees in the front-to-rear axis.
            The Linkert Book
            • jug
              • Jul 2018
              • 112
              Kitabel, with going to these dimensions what will the c r be? I think I have seen some where that flatheads maybe should not go to more than 7 to1. That right?
              • kitabel
                • Sep 2018
                • 471
                All flathead engines have a "breathing vs. static CR problem", as the CR goes up it restricts gas flow across the deck to the bore, but there is no fixed number. The Ford V8 ran numbers as high as 10:1, following the old rule "if you can't get much charge in there, compress the %@(:{+$ out of it!". Engines with low VE (a KR is far better than the Ford) don't need much transfer area because there isn't much charge.
                The major factors:
                1. bore and stroke (longer stroke can be higher)
                2. negative or flush deck vs. pop-up (allows higher)
                3. distance from the bore edge to the outer edge of the farthest valve seat (closer allows higher)
                4. valve seat reliefs (allow higher CR by improving gas flow)
                There are significant differences between H-D models (W vs. WR), and between H-D an Indian.
                The numbers mentioned will not create problems.
                I suggest light reliefs on all 4 seats.
                The Linkert Book
                • kitabel
                  • Sep 2018
                  • 471
                  30 tooth is really tall, you may not like it. Many people found a 27 easier to live with. I hope you don't have N50-15 rear tires?
                  Downside of high CR:
                  1. more knock sensitive
                  2. fixed spark not a good idea, your auto-advance is probably OK for now
                  3. after break-in go to a colder plug to test
                  4. add .002" to valve lash until the seats break in
                  The Linkert Book
                  • jug
                    • Jul 2018
                    • 112
                    Running 30 tooth was rough on clutch on a sick engine. Had broken rings on rear cylinder and scored. New style .020 pistons sure to help. Running 195/70r14 tires and hoping the rebuild will be the answer. May have to look into clutch improvements with that gearing.
                    • kitabel
                      • Sep 2018
                      • 471
                      Those tires don't help.
                      The Linkert Book
                      • jug
                        • Jul 2018
                        • 112
                        Yes, been thinking of that but wondering what combo will fit best. Maybe some one out there will come up with something good to add. don't want to go back to the old 500-16s.
                        • kitabel
                          • Sep 2018
                          • 471
                          The lightest thing you can find, it's a giant millstone.
                          The Linkert Book
                          • jug
                            • Jul 2018
                            • 112
                            maybe when a guy gets pushing 80 he should forget the hot rod stuff.
                            • jug
                              • Jul 2018
                              • 112
                              I know this a little different angle but some of you guys have helped a lot so far with my questions. What about torque cones for use in drag pipes? I see people use them but will it do anything for the old "45" with the things we talked about before? Never know if you don't ask questions, right??
