32V drive sprocket
  • Fineline
    • Aug 2017
    • 31
    32V drive sprocket
    Ok I started the 32V for the first time. I have a little wiggle from the drive sprocket . How tight can you make them with out damaging the engine shaft .plus a little to much oil coming out of the primary chain oiler any ideas thanks
    • 4789
    Make sure you have the right key in the sprocket shaft. Generic don't work, it must be the right type. If it sits a hair high the sprocket won't seat on the taper. There should not be any wiggle, period. And they can be tight, it won't hurt the shaft, just not so tight as to rip the threads off.
