32V solo seat mounting
  • Fineline
    • Aug 2017
    • 31
    Hi again. I'm installing my new solo seat and I see a picture of three spacers that are between the seat and the tee bar my seat has two studs in the back on each side and one in the front . What is the arrangement of all these spacers . Thanks
    • 4789
    The "spacers" are to adjust the seat height, so the arrangement is whatever you prefer. They can be any combination above or below the seat tee based on your preference of height and tilt. The front mount uses the curved washer to tighten no matter what the rear spacer configuration is.
    • Fineline
      • Aug 2017
      • 31
      Thank you. First one learning alot
