32V Tail light
  • Fineline
    • Aug 2017
    • 31
    32V Tail light
    Hello all I'm coming to the end of this project 32V and you would think that after all the pictures I took that I would get a good idea were to mount the rear tail light and rear stand bracket. With that being said does anyone know exactly where to mount the tail light and rear stand bracket I have the tail light about 4 1/2 inches from the end of the fender but does the stand bracket bolt to any of the tail light holes and do I drill out the rivet in the centre of the rear fender to accommodate the rear stand bracket and add a bolt . Thanks again some pictures would be great also
    • 5948
    I hope this helps.
    • Peter Cooke
      • Aug 2012
      • 566
      Bottom 2 holes are for the stand catch. The next 3 are for the tail light. The hole I've marked 'fill' is the top tail light hole and doesn't match my tail light bracket by approx 1/4" so I'll fill and re drill to suit. The 6th hole, offset to the right, is for the tail light wire clamp. I'm away with work at the moment but if you can wait until the weekend I can get dimensions for you.
      • Fineline
        • Aug 2017
        • 31
        Thank you it's a great help
        • Peter Cooke
          • Aug 2012
          • 566
          Here you go. I used the center line of the center rivet as a datum. Don't forget to check dimensions against your actual stand catch and tail light bracket. That 5 3/16" dimension needs to be changed to 4 11/16" to suit my tail light bracket.
          • Fineline
            • Aug 2017
            • 31
            Thanks so much for the help !
