1930 - 33 VL carb support bracket query
  • 1930 - 33 VL carb support bracket query
    Would anyone have a 1110-30 1930 - 33 VL carb support bracket they would sell or
    if not a picture and if possible a few measurements would be much appreciated as I will make one.
    If you are going to Oley and care to keep this in mind I'd be happy to buy it if you find one.
    A unicorn might be easier. Thanks
    Bob Appleton
    aclmotorcyclecollection.com
    www.aclmotorcyclecollection.com
    Bob,
    I'll dig mine out on the weekend and get pics & dimensions for you if you can't find one.
    Try Steve at VL Heaven. I think I got it from him.
      Dear Bob, I've still got a few of the ones I made, a plain L-bracket, which I thought at the time was correct and which do the job. Subsequently I had a very original 1933 VL in the shop and found out the bracket is S-shaped and rests on the crankcase between the cylinders. I had some made to match, but they were formed out of thin stainless and need two for the correct thickness. Contact me through VL Heaven and I'll send you one or both.
        Thanks Peter & Steve
          Looks like I need to contact Steve as well Bob. Mine is the L shaped bracket.
