wheel offset for 1935 or 1936 Indian Chief?
  • Paul Kleber
    • Feb 2018
    • 9
    on a 1935 or 36 indian chief what is proper rear wheel offset when respoking?
    • 965
    The front is 3/4 from the drum outer flange to the rim edge with one piece drum and hub original wheel. I cant give give accurate measure for rear because its mounted with drum.
    I like to true in frame to be sure.
    • Paul Kleber
      • Feb 2018
      • 9
      thanks tom for the info
        • 2034
        posting in Indian section may get more response
        • gsottl
          • 216
          I checked on 2 1935, 1936 Chief rear wheels I have here. On both wheels the rear hub protrudes 1 5/16" from the edge of the rim when mesured on the left side with a ruler laid over the hub.
