Duel plug VLD
  • Lee.c
    • Feb 2017
    • 16
    Duel plug VLD
    Hello all. My name is Lee and I've been looking around the site for quite a while, became a member last year. I figured it was time to post something I've been putting my grandpas 34 VLD back together after being taken apart since sometime in the late 50's to early 60's. I got the engine mostly competed today and was curious if anybody has seen any heads like these before or has any info on them. I would like to thank everyone for such a great website loaded with knowledge.
    • 5955
    So you also need dual coils.
    • Lee.c
      • Feb 2017
      • 16
      Don't know if I'll run 2 coils or not, got a long ways to go until I get to that point. The story I was told was that you could switch the wire to the other plug when you were racing if you fouled out the first plug
      • sny
        • Jun 2017
        • 94
        I don't know anything about them but they look neat! Cheers
          • 4789
          Isn't that the same outfit that made the alloy ones? I believe they were out of Portland.
            Yes, it looks like a steel version of the Smith 7-bolt alloy heads out of Portland Oregon, adapted for twin plugs. Alloy heads were tested in California in 1935 but never went into production, being superseded by 9 bolt iron heads the following year. I don't know if it was the Portland heads tested in 1935, or if these were later aftermarket items. I've not seen these iron 7-bolt two plug heads before, cool! Is there a compression code stamped underneath?
              • 5955
              Seems like an unused plug would get a good layer of carbon on it.
              • Lee.c
                • Feb 2017
                • 16
                Thanks for all the replies! These have a a couple words before the raised Portland Or casting but sadly corrosion got the best of them and I can't make out what they are. After reading the replies Smith might be one of them. I couldn't find any stampings anywhere when I was cleaning them up. Here's a few more pictures if anybody wants to see them
                • Lee.c
                  • Feb 2017
                  • 16
                  Same thought crossed my mind to, seems like if you fouled one the second one wouldn't light either
                    Here's a picture of an aluminium head on my 35VLDD. Looks like this and the twin plug head came from the same or similar mould.
                    • vride5
                      • Dec 2002
                      • 93
                      could you show a picture of the bottom? there is only 1/16 inch or so of clearance in there before it hits the piston unless its sitting in a pocket. from the top it does'nt look as if its sitting on much iron.
                      thank you
                        • 6033
                        Lee.c, that is a fantastic aftermarket VL item, and something that will separate you from the crowd. Does anyone have an idea when, and for how long they were sold? Also, did they improve performance, or just a cool gimmick?
                        • Lee.c
                          • Feb 2017
                          • 16
                          Thank you Steve for showing that picture. Seeing yours I'm convinced mine had the same script. I think you're right about mould, if mine were in better shape they would look just like yours. Great book by the way, it's really helped with this project.
                          • Lee.c
                            • Feb 2017
                            • 16
                            thank you
                            Here's a picture from when I was cleaning them up
                            • Lee.c
                              • Feb 2017
                              • 16
                              Thank you! I'm really looking forward to being able to ride it and see if anyone notices it.
