1930 V trans
  • sailfish
    • Sep 2010
    • 175
    1930 V trans
    What is the plunger on top of trans used for ? Is it to help drain the trans
  • RCamp
    • Jul 2012
    • 99
    It's used to align the kicker gears. If you feel resistance when applying pressure to the kicker arm, you push the plunger with you foot to align the gears. Most people don't do this and you end up with f***ed up kicker gears.
      • 2177
      The constant mesh kickstarter wasn't introduced on the Harley big twin gearbox until 1931, so the boxes before this had the 2134-16 starter gear 'adjuster' in the top of the case. If your starter gears got jammed, this drives a hardened tapered pin between the starter gears to reset them.
      • sailfish
        • Sep 2010
        • 175
        Thanks for the great answers
