VL Dash Variations
  • downunder vl
    • Oct 2009
    • 139
    VL Dash Variations
    VL Dash Base variations.
    I have been able to accumulate enough parts to build a long awaited dash for my 1935 VL. I have 3 bases all of which have a different configuration of ammeter holes. Can anyone identify the years/models for any or all please. I could send them off to Steve and I do welcome his response but I thought that this might be interesting for others to see. I have labelled them as A, B and C.
    Dash A
    Dash B
    Dash C
    If anyone has an untouched 1934-5 dash I would also be grateful for a photo of the underneath showing all the terminals etc.
    I have a 2 top sections and I am still trying to shed something definite on the top that has had no hole created for the dome light. You can see where it should be by the inside plate but it has never been cut.
    I think dash base A is the latest one, because the factory have ovalised one ammeter terminal hole to allow for the later white face ammeter which has a different pitch on the terminals from the earlier bar and shield type. On the dash tops, I'm guessing one comes from a 1930, 1931 or 1936 magneto model where the dash lamp was not used.
    • MMasa
      • 1192
      When did the mount stems get the reinforcement plates added?
      Mark
      Mark Masa
      www.linkcycles.com
      • downunder vl
        • Oct 2009
        • 139
        Thanks for the input Steve.
        Mark. Can you expand on you comment please. The 3 dashes all look the same where they screw on.
          Dear Mark, I think the 4526-26 switch guide plates were there from the beginning, at least on the VL dash. They are often missing or broken, and not in the 1930-40 Harley parts book. I guess they are to stop the switch stems rattling, and maybe to help with grounding. Don't know if they were used in the JD dashes.
          • MMasa
            • 1192
            Steve
            I'm talking about the extra plates of steel that are spot welded to the backside of the mounting brackets of the dash base plate. Looks like they were added to help stop stress cracks from developing due to vibration.
            Some or all 29 models DIDN'T have them. I'm just wondering if you know when they came into use?
            Mark
            Mark Masa
            www.linkcycles.com
            • downunder vl
              • Oct 2009
              • 139
              Hi Mark and Steve.
              Dash A has them. On the inside of the legs where the dash attaches. They go about 2/3 of the way up the each leg.
              Dashes B and C don't have them.
              Good detail.
              Phill
              • MMasa
                • 1192
                Phill
                Exactly the detail I was asking about. Just wondering when it started.
                Mark
                Mark Masa
                www.linkcycles.com
                  I'm guessing 1929 because the difference between mounting bolts 4506-29 and later 4506-29A might be that the later bolt is longer to allow for the reinforcing plate.
                  • downunder vl
                    • Oct 2009
                    • 139
                    I would still be really interested in a photo from below of a virgin dash if anyone had one. In discussion here we have a theory that the dashes and wiring loom were assembled and then attached to the bike.
                      When I've seen the odd original VL dash it has had wiring attached. You can see from the wiring diagram that the main harness comes up through the hole in the right hand side of the base and is partly wired to the top of the dash contacts rather than the bottom.
                      • Tom Wilcock
                        • Jan 2008
                        • 333
                        VL dash variations
                        Here is a picture of the complete original dash for my 1930 DLD. I would assume the 1930 VL was the same. The other dash with very little remaining wiring is from my 1930 C single.hd dld 003.jpghd dld 005.jpg
                        • MMasa
                          • 1192
                          Do the mounting tabs on either have the reinforcements as shown earlier in this thread?
                          Mark Masa
                          Mark Masa
                          www.linkcycles.com
                          • Tom Wilcock
                            • Jan 2008
                            • 333
                            Mark
                            Both dashes have the reinforcing on the mounting tabs.
                            • MMasa
                              • 1192
                              Thanks Tom
                              Mark
                              Mark Masa
                              www.linkcycles.com
