cylinder top casting# WL45
  • hdhikaru
    • Feb 2010
    • 217
    casting# rear is 6 front 5 should be same#? whats the difference between 6 and 5 ? s-l16002.jpg
    • 2024
    I am assuming that these are aluminum. The 5 I believe is a low compression head commonly found on WLA's. You should be able to see the difference in the deck height. Jerry
    • hdhikaru
      • Feb 2010
      • 217
      thanks Jerry, so they should be the same#
        • 2024
        Yes. It is possible to mill them to the #6 deck height and then cc them to be matched. I have done it a couple of times. Jerry
        • hdhikaru
          • Feb 2010
          • 217
          ok, thank you Jerry.
