1967 GE spark plugs
  • pan620
    • Oct 2016
    • 223
    1967 GE spark plugs
    Any advice of what spark plug to use in a 67 GE motor? Thanks Dave
  • Sargehere
    Member since 1972
    • Jul 2006
    • 971
    If it's an 18mm plughole, start with a Champion D-16 or equivalent. Won't hurt it at all.
    Gerry Lyons #607
    http://www.37ul.com/
      • 4789
      Standard H-D plug was a 3-4. The equivalent is a Champion J12Y. The standard iron heads on a '67 are 14mm, unless they have been changed to earlier aluminum heads which are 18mm size. #2 H-D were used on city traffic engines to prevent fouling on continued low speed use.
      • pan620
        • Oct 2016
        • 223
        The threads are 14mm. so I will go with the 3-4 H-D plugs thanks for the help.
          • 4789
          Pan620,
          Make sure you use the short reach plugs. H-D also sold a long reach 3-4 which will not work in your GE.
            • 5955
            Champion UJ12Y work well in my Servi-car.
            • jaybee47
              • Sep 2017
              • 4
              Just acquired a '66 GE police trike.
              Its spark plugs are marked Champion J16C.
              Good to use?
              What spark plug would be recommended for occasional short distance riding?
              Thank you.
