VL Trans Gearing Location??
  • wideglide38
    • Jul 2008
    • 656
    For the VL 3-Speed transmission, is the gearing inside the gearbox as noted in the attached photos? I am trying to set up my shift linkage and want to make sure I have correct Gear Lock Plate (2239-28) orientation.
    William
    William Edwards, AMCA #10035
  • RCamp
    • Jul 2012
    • 99
    Yes, your photos are correct.
    • wideglide38
      • Jul 2008
      • 656
      Great and thanks! William
      • Bob Appleton
        • Nov 2013
        • 28
        Nice pictures. Agreed correct. Be sure the gear lock plate shaft 2241-15 is set such that a "point" of top that engages with the shifter shaft 2229-30 is pointing rearward and not a "flat" or you won't shift at all. Happy to send a pic if you need one.
        www.aclmotorcyclecollection.com
        • wideglide38
          • Jul 2008
          • 656
          Bob,
          The photos were stripped from ebay - I just added the text. Yes, I believe I understand what you saying (see attached photo). And that is what I'm trying to figure out is indexing the shifter shaft?
          William
          • Bob Appleton
            • Nov 2013
            • 28
            Yes that picture shows it positioned correctly (point, not flat of the "bolt head" pointing to the rear.
            Gear shifting fork 2246-15 is below the gear box cover and also in line with the point or approx center of the gear lock plate.
