Frames for big twin flatheads
  • John m kelly
    • Dec 2015
    • 21
    Hello is am starting a build on a 1937 big twin Harley flathead. I do not have a frame but plan on buying a replica model. My question is where the flathead and knucklehead frames interchangeable during those years when both engines were available. If I chose a 1941 frame say would the 1937 motor fit. I know that the top motor mount is different for those engines but is the frame mount the same.
    Thanks J Kelly
  • vph-d
    • 1088
    BTSV and OHV frames were the same.
    VPH-D
    • John m kelly
      • Dec 2015
      • 21
      Thanks for the reply, that is what I thought.
      • knucklehead 61
        • Sep 2016
        • 350
        1937 & 1941 frames are very different though.
        rake is different also.
          • 6019
          Originally posted by John m kelly View Post
          If I chose a 1941 frame say would the 1937 motor fit. Thanks J Kelly
          Any Knuck motor will fit in any Knuck frame, and Pan, or Shovel frames with a spacer. It's Pans, and Shovel motors that won't easily go into a Knuck frame.
