1941 wld
    • 2025
    1941 wld
    At the Fremont Nebraska AMCA meet this past weekend I bought a 1941 Harley Davidson WLD partial basket case. I got the engine, transmission, frame, frontend and gastanks. Bought this for the son of a friend of mine and was just curious would the cams be anything special and if anything else is?
    Jerry
    • 4791
    Only the top end Jerry. The cams are the same, so is carb. The cylinders should be big fin, medium size intake, with standard straight valves. The heads should be aluminum high compression (three bar). Otherwise identical to WL.
      • 2025
      Thanks Robbie - I thought so. Jerry
