What's available for modern replacement spark plugs for a VL? An 18mm plug with a screw on terminal cap to accept the orignal style loop connector wires? Heat range #3......anyone?
What's out there for VL spark plugs?
I've used a lot of NGK A6 and A7 plugs but now moved on to the Champion D16 which are maybe easier to find and work just as well. The original VL plugs were 1 3/8" across the flats, with the later 1936-48 Globe and Harley plugs 1 1/8", then the modern NGK 1" and the new Champions 7/8". For judged bikes it is always nice to run the bike on modern plugs then find an old pair for display.
I also have been using the D-16 plugs now for years for my VL's, knuckles, BTF. You can get them sat most NAPA stores as well as Tractor Supply. If they don't have them in stock it only takes a day or two to get them.
Tom ( Rollo) Hardy
AMCA # 12766
