1934 VLD exhaust
  • 1970 XLCH
    • Nov 2010
    • 177
    1934 VLD exhaust
    Questions on the " High flow " exhaust on my 1934 VLD .
    Does the " rear hanger ( 1064-32 ) " bolt to the inside or outside of the frame ?
    Do the pointed parts of the " rear hanger clamp ( 1065-32 ) " go up or down ?
    I am having trouble getting all the clamps to line up & have the rear stand working . The top clamp that bolts to the fender brace ( forgot to get that part # ) is about an inch short of lining up with the fender brace bolt . That is with the " rear hanger " clamp bolted to the frame, which dictates how high the muffler tip can go .
    Are there bad clamps out there ? I bought these back in 2004 from Harbor Vintage .
    Hope This isn't too confusing .
    Any help would be great . Thank you , Mike
  • 1950Panhead
    • Jun 2010
    • 343
    Muffler clamp on outside, pipe tucks between wheel and stand then curves out, there is a clamp between pipe top and right fender flip bolt.
      The problem is usually with the repro muffler tail, which isn't kicked up high enough to meet the bracket.
      • 1950Panhead
        • Jun 2010
        • 343
        Time to make your own bracket when that happens.
