I'm overhauling a rear axle to replace a bent axle shaft and I have a question about the outer bearing housings. I've heard that one is right hand threaded and the other, left hand threaded. I got the one on the "short" side removed with no problem using the Kemco tool and it was threaded normally (rotated counter clockwise to come off) but the other is on pretty tight. Before I bugger this one up can anyone verify that this one is left hand threaded?
Servi-car rear axle question
