Primer Cups
  • bselph
    • Jun 2009
    • 311
    Primer Cups
    What is the difference between the primer cups for a VL vs a J model?
    Bob Selph
    1933VC/1934LT Sidecar
    1940 Sport Scout
    AMCA#15215
    NONE! What's the difference between a VL and a 37 U Primer? NONE! They were all the same. Bob L
    • bselph
      • Jun 2009
      • 311
      That's what I thought. Competition Distributing shows two different styles. The J model has a short non threaded section that protrudes into the cylinder.
      Bob Selph
      1940 Sport Scout
      AMCA#15215
        I find it weird that the factory would have something protrude into the combustion chamber. Got to go look at this item.
        • MMasa
          • 1192
          Bselph
          Somewhere around 1930 there was a change to the shape of the "knob" of the primer. All primers I have ever seen on JD's are flat topped with just a small countersink around the primer hole. The later style has the whole top face of the knob "cupped". It's almost like a bowl. I'll have to put the two styles side by side to see if there is a difference in the length.
          Mark
          Mark Masa
          www.linkcycles.com
          • Peter Cooke
            • Aug 2012
            • 570
            Mark is correct.
            See post #48 of the link
            http://www.antiquemotorcycle.org/bbo...toration/page5
              Well, now I know my 37 came with the wrong ones in it. Bob L
              • MMasa
                • 1192
                Peter
                Thanks for the link. Saved me from posting some pics. That was exactly the feature I was describing.
                Mark
                Mark Masa
                www.linkcycles.com
                • bselph
                  • Jun 2009
                  • 311
                  Slocombe just confirmed that in 1930 the face changed from being flat to cupped. Still not sure about the unthreaded area on the bottom.
                  Bob Selph
                  1940 Sport Scout
                  AMCA#15215
