VLH Forks
  • danf19
    • Apr 2013
    • 246
    VLH Forks
    I am looking at a set of forks that the seller says are '36 VLH forks. Before I commit, can anyone give me any dimensions, numbers or anything else that I could double check on them please. I know the grease fittings should be on the reverse but looking for other specs to check out. A picture would be great as well.
    thanks
    Dan
  • 1950Panhead
    • Jun 2010
    • 343
    The front fork has a bracket between the spring seats, main fork has grease fitting on back, both are 36 only.
