tools
  • johnnyfire
    senior member
    • Dec 2005
    • 100
    tools
    I'm looking for a source for a tappet block puller and a valve spring compressor for a VL.Does anyone have pics of these tools?Thanks
  • frichie68
    Senior Discount
    • Apr 2012
    • 646
    Homemade valve spring compressor . . .
    Used to be a flywheel holder for something else. I removed the bolts and did some grinding to make it fit better when I put it back together.
    Rich Inmate #7084
      Dear Johnny, Steve White at Vintage M/C Northwest should still have the tappet block puller. He's on 253.846.2775 and is there every day. I'm using a valve spring compressor from my 1948 Land Rover which works just fine. I'm sure generic tools could be adapted. If sufficiently desperate or budget minded, two people with large screwdrivers can get the valve springs out with the cylinder upside down on the work bench.
      • johnnyfire
        senior member
        • Dec 2005
        • 100
        Thanks,I'll look into that.
        • johnnyfire
          senior member
          • Dec 2005
          • 100
          Thanks for the idea
          • RPjr
            • Dec 2006
            • 57
            Home made
            On the bike or off.
