HD ULH + M51 adjustment
    • 8236
    Originally posted by duffeycycles View Post
    ...,he freaked,YOU RODE MY BIKE?!!!I..
    Did you charge him your time, or ride it for free, Duffey?
    PS: My insurance makes me invoice everything.
    PPS: I guess you missed my point about Tedd's.
    PPPS: Back to topic: Antti!
    Keep those commercial one-size-fits-all PEEK seals snug, and re-snugged, and snugged again...
    • asavolai
      • Dec 2014
      • 14
      Hi,
      I checked ignition, it okay.
      I have one-size-fits-all peeks, so will tighten them. But after I change the manifold. I decided to change the manifold and M35TP carb back. If bike works after that, then the problem is in the M51 carb.
      And the I need to check if venturi (and everything else) is backwards...
      Thanks!
      Antti
      • asavolai
        • Dec 2014
        • 14
        I changed back 4 bolt manifold and M35TP carburetor. And the bike works very well. So there must be some odd in the M51.
        Where to start? float level? Venturi?
        I can just barely see light between venturi and body. Can that be the reason for problem?
        I think there's not enough gas going to engine with M51(L)
          • 8236
          Antti!
          There is only one float level: ΒΌ inch.
          Beware of thick commercial gaskets, appropriate for M53s and the like, but use a different setting to accomodate it.
          Usually a few small issues add up to make a tuning problem.
          My approach is to fix everything, and problems seem to "come out in the wash".
          Since its an acceleration issue, I would inspect the fit of the nozzle spigot within the venturi's hole.
          (A steel (what were they thinking?) reproduction just crossed my benches with a .201" hole for a .1875" spigot. The manufacturer was obviously "lost in the woods".)
          Worn holes can be saved with a very thin PEEK seal. Worn spigots can be sweated with soft solder and lathe-cut, or replaced.
