U UL Head Gasket
  • kjsisterson
    • Jul 2013
    • 20
    U UL Head Gasket
    I need to buy a set of head gaskets. What should I get? Fiber/tin or Copper or?
    Thank you,
    Kevin
    Copper. Anneal it with a torch. Lightly glass bead it to clean. It will end up sealing better than any Teflon fiber gasket could. It will fill every last void. Bob L
      • 8236
      Thank you,
      Kevin
      Kevin!
      I have an opinion that others may argue or distain, but first please tell us if you have cast iron or aluminum heads.
      PS: Dressing your heads and cylinders to 'flat' should eliminate "voids", of course.
      • kjsisterson
        • Jul 2013
        • 20
        I have cast iron heads.
        The gasket gave out on the So Cal Road Run last weekend of course!
        Kevin!
          • 8236
          Well Kevin,
          One general rule of thumb is copper for cast-iron, composite for aluminum, but I preferred composite for both.
          Head gaskets do not blow themselves: It takes excessive heat.
          Please first inspect your head and cylinder deck for warpage, particularly over the intake port. Then please bubble-test your manifold, and double-check your ignition timing before putting her back in service, as those are the two most common causes for a spike in temperature.
          Good luck,
          • kjsisterson
            • Jul 2013
            • 20
            HEllo Cotten,
            Thanks for the tip.
            I will check all those things.
            I did find a loose head bolt exactly where the gasket blew through. It was a metal gasket, that attracted a magnet with some kind of cover materiel.
            Kevin Sisterson
            President
            Perros Viejos Chapter
            AMCA
            San Diego, California
              • 8236
              Kevin!
              Even with the metal it is considered "composite" and goes back at least as far as WWII, as that is what I found in an NOS WLA kit.
              Its hard to be religious about re-torques, I know.
              Gotta torsion torque wrench? Adapters are easy.
                With iron heads I pull the head bolts down to 65 pounds feet on the VL. Then go over the bolts again by hand the first time the engine gets hot. Also run that 7/16" x 16 tpi tap down through the bolts holes in case the bolts are bottoming on carbon deposits, especially if the heads have been skimmed.
