1938 ulh
  • pete reeves
    1938 ulh
    Can any body help I am restoring an early 1938 ulh and have a problem in working out how the speedo cable is cliped to the engine the parts books says that the 1110-33 carb support bracket is used and that111 36-37 clip is used for the cable where should this clip be mounted if I fit it on to the same motor stud as the carb bracket it will distort the clip if I fit a spacer nut between them the cable fouls the gas filter .Do I have the correct cable clip? the one I have is a simple P clip with the correct sise hole for the motor stud.Thanks.
