VLD Fork lock replacement challenge
  • NCriding
    • Jul 2014
    • 71
    The fork lock plunger in the VLD was completely rusted in place, and complete replacement of the lock and plunger was the only answer. I've posted a few picks to show the fun that was involved.
    Removing the lock and tumbler was the 1st issue. Even with the locating pin removed, the cylinder wasn't going anywhere. Slow and steady grinding by hand. Success was finally achieved with the lock, then I drilled and tapped a bolt into the plunger and tried to extract it with a slide hammer. No luck with that arrangement and ended up drilling/grinding the entire plunger out. I've got cutting tools that a Dentist would lust after, so managed to remove it without touching the walls of the hole. No photos of that, as it's too dark that far up into the frame.
    1936 VLD in process
    1969 Honda Z50 K1 perfect!
    1985 Yamaha RZ350 resto-mod
    2006 KTM 950 Adventure
    2019 KTM 300 XCW
  • Jim
    • Sep 2001
    • 784
    Nice Job! Two sayings come to mind.... Where there's a will, there's a way! and Patience is a virtue!
    Jim
    AMCA #6520
    • wideglide38
      • Jul 2008
      • 656
      Thanks for the post & pics. I have to do the same to my frame!
      William Edwards, AMCA #10035
