Brake Pedal Help.....
  • Andy Lux
    • Dec 2012
    • 41
    Looking for a little bit of help with my Brake Pedal for my 1932 R build. Please see the attached pics. The pedal I have has all the correct casting numbers on it, but it doesn't look exactly the same as the one that Johnny Sells shows in the manual. It appears to be missing the bump towards the back of the backbone. I have included a pic from the restoration manual also. I'm not sure if what I have is correct or not. Any clarification on this would be greatly appreciated.
    Andy Lux
    • 2030
    that looks like an early WL lever-I don't have one here,but is your casting # 328 30 instead of 326 30
    Your lever should have another hole that lines up with the hole that is on your's-pin goes thru both
    • Andy Lux
      • Dec 2012
      • 41
      Thanks for the responses I received on this. Turns out the pedal is off a VL.
