Where Does 1942 WLC Voltage Regulator Mount???
  • wmarketst
    • Mar 2015
    • 9
    Hey Guys
    I just got a 1942 WLC and the previous owner had bolted the Voltage Regulator to the battery box.
    I'm trying to re-wire the bike and I want to locate the Voltage regulator in the correct place.
    Can anyone shed some light on this???
    I purchased a mount from 45 Restoration (see photo attachmnt) but I can't figure out if it will work, and if
    so where it would mount???
    Don
  • vph-d
    • 1088
    It looks like you have a 12 volt system judging by the -65 Bosch style regulator. That mount hangs off the end of the generator, at any rate.
    VPH-D
      The WLA didn't use a regulator. They had a cutout relay that was mounted on the engine.
      • murph
        1959 xlch
        • Jun 2009
        • 226
        The style you have mounts like this
        1959 XLCH
          The original cut out relay mounts on the front of your engine cases inside of the front exhaust pipe.
