1954 "G" motor piston question.
  • tracerbob
    • Nov 2014
    • 28
    I've got a set of nos cylinders to replace the old cobbled up ones on my 45 servi-car. So, in locating a set of pistons I find they're are two different kinds. Early (253-29A) and late (253-55A). What is the difference between the two and does it matter which set I use? And does a sevi-car use a completely different set?
    Robert
    • 4786
    The difference in the -29 and -55 pistons is in the width of the rings, the -29 is thicker while the -55 is the new thin type with better oil control rings. Either will fit any 45 application and Servi-Car pistons are the same as all the rest. The compression differences are in the heads.
    • tracerbob
      • Nov 2014
      • 28
      Thanks for the info. I've got one more question. Would a servi-car run a looser piston cylinder fit the a WL? And what would that be?
        • 4786
        No, they were both considered extreme duty units. Aftermarket pistons generally require more clearance. Break-in specs are the same.
        • tracerbob
          • Nov 2014
          • 28
          That works for me since I have a set of NOS std and .010 piston sets.
