VL Bent Cross-over Tube
  • Carter32
    • Jan 2013
    • 19
    Good Morning I'm working on a 1932 VL frame with a bent cross-over tube. I was wondering if anyone has had any experience in straightening one of these.
    • 2024
    That is a fairly easy fix compared to some things. As much as I hate to put heat to a frame I do not mind having to use it here because a failure would not be terminal. I usually knock the bushings out and use a shaft that is a loose fit to force it straight. Replacement is not out of the question either.
    Jerry
    • Carter32
      • Jan 2013
      • 19
      Jerry - Thanks, I'll give it a go.
