1936 VLD fork spring shroud mounting tab
  • NCriding
    • Jul 2014
    • 71
    My 1936 VLD spring fork (2606-30) is clearly not a 1936 piece, it doesn't have the bracket welded on to hold the fork spring shroud (2608-36). The rigid fork (2604-30) is correct with the grease fittings pointing back.
    I can fabricate a bracket, but I don't have the dimensions. Can someone tell me the length, width, thickness? Is it just bent 90 degrees and welded? I see that it then is tapped for screw 051 (1/4 x 24). A close-up photo would be great if anyone has one.
    Thanks!
    1936 VLD in process
    1969 Honda Z50 K1 perfect!
    1985 Yamaha RZ350 resto-mod
    2006 KTM 950 Adventure
    2019 KTM 300 XCW
    I've made a bracket in case anyone needed one. Contact me through www.vlheaven.com if interested.
    • MMasa
      • 1192
      Did 1936 RL's have the same tab?
      Mark
      Mark Masa
      www.linkcycles.com
        Dear Mark, I don't know for sure but it must have been very simiar. The fork shield is a one-year part for 1936 on the VL, but the small twins used a shorter shield 1936-39 as they still had the I-beam forks.
          • 2044
          Mark,The book by Johnny Sells has a prototype photo showing the spring cover,but no screw in the hole to the mount!
          I'm sure they had the mount.Spring fork casting #2 on '36 45"
          My '38 & 39 45"spring forks have the casting # facing forward with the spring cover mount being the giveaway-it can't go towards the back
          I will try to take pic
            • 2044
            Sorry about poor pics,the '36-'39 45" sping shield mount is about 1-3/8 front to back X 1-3/16 tall X more than 1/8 thick
            drilled and tapped 14-24---mine is bent up & back!
            • NCriding
              • Jul 2014
              • 71
              Thank you, that is what I needed to know.
              1936 VLD in process
              2019 KTM 300 XCW
