Woodruff Keys
  • johnnyfire
    senior member
    • Dec 2005
    • 100
    Woodruff Keys
    I'm trying to put a starter clutch gear back on a VL.It has 2 Woodruff keys that fit in the grooves on the Main shaft and grooves inside the gear.They dry fit well,but when I try[2 hours] to get it all together the damn keys slide back and jam into the main starter gear to the rear.AGHHHHHHHH I've clamped the main gear back-its got a spring behind it,but no luck aaaaaaaaaaaaaaaaaaaaaaaghhhhhhhh help
    • 6033
    I've used a center punch to raise a bit of metal on the key so that you can drive it into it's slot. Also make sure there are no burrs on the leading edges of the key that will catch on the gear key way.
    • sirhrmechanic
      Vigilis
      • Dec 2010
      • 1147
      Drop of red loctite or Crazy Glue in the groove can help keep it from spinning backwards.
      Cheers,
      Sirhr
      • MMasa
        • 1192
        Are you sure that it uses D shaped Woodruff keys? If it's like a JD, then it uses rectangular key stock there.
        Mark
        Mark Masa
        www.linkcycles.com
        • johnnyfire
          senior member
          • Dec 2005
          • 100
          keys
          Mark
          Thanks for the tips,I ended up using one rectangular and one d shaped.
