New source for ul cylinders
  • moldthread
    • Jul 2009
    • 32
    We are proud to announce that Enfieldracing.com has completed the purchase of all the flathead casting patterns from S & S Cycles. This includes the UL cylinders, engine cases and cam cover, K/KR cylinders, Indian Scout and Chief Cylinders, and Henderson 4 cylinder. These are the same patterns used by Anders Nygren of Sweden, manufactured under the FLATHEAD POWER name. We expect to be in production of the UL cylinders by summer 2015, with the K & KR cylinders right after that, then the UL Engine cases which will be perfect for Magnum Engines.The cases will be cast in 356-T6 aluminum which is 40% stronger than what the factory used.
    All parts will be cast and machined in the US in small lots to the same exacting standards that we have established for our existing parts.
    This will greatly compliment our line of 648 Indian cases, cylinders, WL/WR/KR cams, heads and other race parts, as well as our Rubber Ducky Floats and Peek Intake Superseals.
    Bruce Argetsinger
    AHRMA Dirt Track # 67J
    Bruce Argetsinger
    AHRMA Dirt Track #67J
    www.enfieldracing.com
  • billpedalino
    • Mar 2005
    • 1096
    Best of luck on your new expansion venture Bruce - I hope you make a million $$ !!
    Bill Pedalino
    Huntington, New York
    AMCA 6755
